From 22's to Stock 18's
Old Mar 22, 2016 | 08:14 PM
  #31
RawFaith's Avatar
Originally Posted by DiscoCam
Go to pepboys or another auto store and buy a wheel lock removal tool. That should easily take the lock off.
went to every partstore around this area and they don't have anything that will fit,
Also there is almost no free space to even try to squeeze anything there....
another ideas that DON'T include a torch ?
Old Mar 22, 2016 | 08:46 PM
  #32
Alex_M's Avatar
Try taking the other 4 nuts off to get as little pressure on that nut as possible, then drill a hole in the middle of the lock nut and use the biggest easy-out you can.
Old Mar 22, 2016 | 09:04 PM
  #33
jamieb's Avatar
Are you using an air impact wrench?
Old Mar 22, 2016 | 09:43 PM
  #34
Bom2oo2's Avatar
Do you have enough original Land Rover lug nuts, to instal 16" wheels,?
The ones that are holding the 22" on your car will not work on Land Rover wheels,
Old Mar 22, 2016 | 10:12 PM
  #35
number9's Avatar
Grinder to make room for tool if not enough to get a socket over it. That ugly wheel may need to be sacrificed. Several youtube videos available for additional ideas.
Old Mar 22, 2016 | 11:32 PM
  #36
DiscoCam's Avatar
He has a good point.
Make sure you have the original lugs or else you can put the original lugs on.
And I think at this point, those 22s are marked for death.
Old Mar 23, 2016 | 01:19 AM
  #37
number9's Avatar
Good points about the nuts. If you need them.
Land Rover Discovery 2 Range and Rover P38 Nuts Set of 20 ANR3679 New | eBay
Old Mar 23, 2016 | 03:15 PM
  #38
RawFaith's Avatar
Thanks for all the replies guys!
YES, I did get a set of OEM lug nuts to install the 16s on the truck.
I couldn't believe how complicated this will be!
Old Mar 23, 2016 | 03:16 PM
  #39
RawFaith's Avatar
this was the closest size but it wouldn't fit because of the wheels!
Old Mar 23, 2016 | 03:18 PM
  #40
RawFaith's Avatar
last resource!
