2in Lift Kit.. Did I miss something?
Can you replicate the noise if you rock the truck back and forth from outside? If so your Watts linkage bushings may be shot. I included a pic of the watts.
I've had that sound and it is not the sound of shocks topping out.
It is a sound that happens AFTER you go over a speed bump and the spring releases so powerfully as to slam the wheel/tire back down to the ground abruptly.
I have 2" lifted springs and standard length shocks.
I was advised by the most reputable dealer on this site that 2" lift springs do not require +2 shocks. Only over 3" lift requires the +2 shocks.
I had this happening to me after I installed my lift... it was my rear shock not being torqued down correctly and it was moving around every time I rolled over a grain of sand. Tightened the bottom bolt and it went away.
Sarge103
Mar 14, 2013 06:45 PM
Fivespddisco
Jun 8, 2010 07:59 PM
