3 Amigos.
Old Jul 1, 2018 | 02:13 PM
OffroadFrance's Avatar
Originally Posted by mollusc
I never got the amigos on mine, but I did get a persistent wheel speed sensor fault and the enigmatic "rough road signal implausible" OBD2 error. Replacing the hub with its sensor in place god rid of the problem permanently. So remember that wheel sensors and wiring issues can cause more than just the 3 amigos to show up.
I'm not too sure on the US D2 models but with a suitable diag you can disable the "rough road implausible" signal as most UK models are already disabled when new, everyone knows UK roads are 'potholed' rubbish even LR
The US seems to have some unique DTC's which are unavailable in Europe.
(my D2 TD5 is LHD and originally destined for Chile (Patagonia) and is ES model, it has everything, bar ACE, which I wanted removed prior to buying it.)
Old Jul 1, 2018 | 02:42 PM
Best4x4's Avatar
I was up at my friends shop in Austin, TX and I hooked my Kalahari up to the T4 so I could enable the Front Fog Lights as a Kalahari didn't come from the factory with them. While I was going thru the various settings I disabled the seatbelt warning & I saw where you can disable the gauge cluster from flashing when removed. I also made it to where my Fog Lights will be on with high/low beams vs just low beams.
I'd buy a Hawkeye if I knew for sure I could modify the same settings as the T4.
LR03NJ
Jun 27, 2018 02:54 PM
batard
Aug 24, 2016 03:30 PM
OffroadFrance
Apr 19, 2014 06:58 PM
rappo999
Feb 25, 2013 08:52 PM
bostongrun
Apr 30, 2012 11:07 AM
