3 amigos, bad abs brake modulator
Old Sep 11, 2008 | 07:22 PM
  #21
Willie 00D2's Avatar
Default RE: 3 amigos, bad abs brake modulator
I have not had the ABS modulator rebuilt yet. The rebuild kit is only about $100. They do need to take the unit out of the vehical to rebuild it. I need to get it done before winter.
Willie
Old Sep 11, 2008 | 07:23 PM
  #22
I will keep you guys posted on the repair job and costs.
Willie
Old Sep 12, 2008 | 05:27 PM
  #23
fsix's Avatar
Hi,
Tested my ABS today and it seems to be working - after reading through the forums, it looks like it could be the Shuttle Valve? or the ABS sensor wire? any thoughts?
Cheers,
Old Sep 12, 2008 | 06:35 PM
  #24
Disco2Guy's Avatar
I doubt the cheaper kit will fix your problem. Fixing the 3 amigos requires a good chunk of change. Those are still cheaper than the $2000 modulator itself, which used to be the only option.
ABS MODULATOR SHUTTLE VALVE REPAIR KIT $67.95
ABS MODULATOR VALVE KIT $729.95
aftermath431
Sep 17, 2013 04:41 AM
corbin
May 22, 2012 11:21 AM
sayeedA
Feb 25, 2012 12:35 AM
azoverlander
Mar 12, 2011 02:16 PM
pilsner
Dec 2, 2008 10:06 AM
