3 Amigos-codes 040 and 114
Old Feb 8, 2016 | 03:37 PM
  #31
number9's Avatar
Default Tool
Would this work with correct sized bit?
Old Feb 8, 2016 | 03:54 PM
  #32
jamieb's Avatar
That should work. You can only get the unit lifted so high because of the brake lines (unclip the lines from the plastic brackets along the firewall for better clearance) and you'll be able to tell when you need to stop lifting. Worst case is the key is too tall to fit underneath. I think 2-inches or shorter should be good. 4mm should be the hex key size.
Old Feb 8, 2016 | 04:08 PM
  #33
number9's Avatar
Thanks, ratcheting holder and bit about 1 1/16". Good to know for when my time comes.
Old Feb 10, 2016 | 08:03 AM
  #34
mln01's Avatar
Originally Posted by Joemamma1954
Don't start it until you have the wires, job doesn't take long at all. 2 foot long wires and 2 wire taps are all that is needed. The instructions make more work than needed, in my opinion. The shuttle valves connect to ground and to the wire going to the ecm. The ground wire and the ecm wire both come out of the abs unit and it does not matter which wire you hook up to which. Cutting the wire from the loom to attach one wire, and finding a ground for the other wire is not needed. They make very good wire taps that you can just tap into the existing wires and be done with it.
Attachment 28993
It's true that Option B can be done without the two-wire trailer wiring connector. I can only guess that perhaps Josh Salas elected to use the connector so that the shuttle valve switches can be more easily removed if they need to be replaced at a later time. It sort of replicates the plug and receptacle setup of the original.
It's also true that using the wire taps is easier than splicing with solder and heat shrink, but in my case I had solder and shrink wrap on hand.
Charlie_V
Aug 27, 2015 04:37 PM
Lincoln Tarantino
Apr 1, 2012 09:13 PM
yuenie
Jan 13, 2010 05:37 PM
Scott R
Oct 18, 2009 12:04 PM
isofast
Sep 12, 2009 04:54 PM
