3 Amigos won't go away
#21
#23
#24
Do your brakes squeak? That squeak and squeal can do a number on the sensors. I made the mistake of buying cheep pads and rotors. They work fine but can squeal something fierce. Sometimes this sets my amigos off.
Also, I did run a code telling me my passenger rear abs sensor was bad. It ended up being a siezed caliper. replaced it and it's been good since.
#25
#26
Should have gone with the Autel 619. Now you know what the code is but you have no way of troubleshooting it. With the 619 you could have pulled up the PIDs for each wheel, jacked up the vehicle so all 4 wheels are in the air and read the live data for each wheel as you put it in drive and brought it up to 40 mph or so. This would show you what the SLABS is seeing and you can pinpoint the issue from there.
cammyr01
01-05-2015 02:42 AM
Solihull
09-10-2014 01:49 AM
