305/60/r18 Whats does my 04 DII need to fit these??
Old Feb 24, 2012 | 11:25 PM
NCguy's Avatar
Default 305/60/r18 Whats does my 04 DII need to fit these??
I do not want to make a mistake but it seems these are really not much larger than the 265/60/r18 that i have now, the current 265 have a ton of room?
Old Feb 25, 2012 | 06:53 AM
Do you have any sort of a lift if so who's and how tall? What sort of wheeling are you doing?
Old Feb 25, 2012 | 09:07 AM
NCguy's Avatar
Default I am geting a really good deal on the tires
I do not have a lift yet, I am waiting for my bonus then I am going to put a lift, bumper w/ winch, off road lights, plugs/ wires and replacing all my coolant lines.
I recently put new battery, altenator, brakes, coolant over flow tank, 2 window actuators, one door lock actuator.
I love my rover and doing all this work, If one does not then owning a rover is not a good idea.
I also may be buying am after market bumper from a 2011 jeep wrangler. I know I will have to do some mods, but I think it will look really good once done.
Old Feb 25, 2012 | 06:52 PM
NCguy's Avatar
Default bump
bump bump
Old Feb 25, 2012 | 07:17 PM
brianb883's Avatar
After just replacing the stock bumper (stock, not aftermarket) on my 04 D2, I can say with some certainty that the way you mount a bumper on one of these is COMPLETELY different than a jeep bumper. Don't waste your time and money modding a bumper that wasn't made for your car. Either cough up the money to get an ARB or look around for a used one. You will thank me, I've put bumpers, both stock and aftermarket on jeeps and literally finished replacing my stock rover bumper an hour ago.
Old Feb 25, 2012 | 10:56 PM
NCguy's Avatar
Default BrianB
Thanks for the heads up, I appreciate the info and telling me so I do not create more work than necessary.
Old Feb 26, 2012 | 07:25 AM
You can't fit a 305 on a stock D2 suspension so better buy a lift first and at that it will be tight plus your diffs will need to be changed to a locker cause the 2 spider gear system won't hold up for that big a tire.
Also plan on loosing around 3 MPG unless you also add some 4:11 gears.
Old Feb 27, 2012 | 11:39 AM
HLC Fab's Avatar
You can run that size tire with a 3" lift with a small amount of fender trimming depending on wheel offset. I ran 305x85 r16 SSR's on DII road wheels with a Terra Firma 3" springs and had no issues. Depending on what style of wheeling you're planning on doing the diffs will be fine for a while. 4.11's or 4.14's will get you pretty close to the stock configuration so if you do plan on wheeling it and drive it around town and want to take advantage of the regear go with something around 4.43 to gain a little pep or if you don't care at all about going above 65mph and the engine screaming you can go the 4.78 route, I wouldn't suggest it though.
tberg44
Nov 23, 2014 05:30 AM
NCguy
Jan 12, 2012 07:36 AM
frat daddy
Jul 11, 2011 04:23 PM
mx468
Nov 22, 2009 01:41 PM
nick1996rover
Mar 8, 2005 10:25 PM
