35s on the D2
35s on the D2
I ended up getting 315/75r16s with 30mm spacers on the Disco. For anyone interested, I had to:
- fit wide arches (a ton of cutting including a HUGE amount of the rear door. you can panel beat them together and seam seal), I fit them high as I could and a few inches apart in the rear
- greg davis rear and rewire turn signals to upper lights
- 4" lift
- 4.37 gears/ashcroft half shafts & cvs, drives well on the highway
- beat in the flange in the front wheel well
- trim the ARB (getting removed soon anyway since bent under winching and bad approach angle)
- remove TF sliders (also getting removed after bending) or trim/cap them
Here's a random photo dump, I could maybe make something more organized when not on my phone. We used loctite foam for a backing then seam sealed the rear doors with 3M seam sealer after beating the panels together with a body hammer. You're really cutting triple metal because the metal that shows when the rear door is open. I ended up beating the innermost metal & fender liner behind the rear quarter up flush. Bumper is also welded to the frame since we had to make custom spacers and the instructions call for it anyway. Like I said, it still rubs in the front. Once that's fixed could probably stuff 37s.
Second pic is with my D1 on a 5" lift and 34s flexed on a stump.
https://m.tirerack.com/tires/Spec.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T%2FA+KO2&partnum=525QR5KO2RWL
https://m.tirerack.com/tires/Spec.jsp?tireMake=BFGoodrich&tireModel=All-Terrain+T%2FA+KO2&partnum=175R6KO2RWL
Alex_M (03-08-2023)
I see people say this all the time but you are running 35s. The truth is no tires are true to size, notice the tires actually labeled 35 only have a true diameter of 34.5". This is true across manufacturers too.
I understand what you are saying and not trying to knock ya, coopers website lists them as 34.53". I have the same size in KM3's and they are 34.6. My stock wheels are 285/75/18 duratrac manufacture spec is 35.1" diameter. Was just saying these 2 tires fit differently on my disco and had to compromise.
I understand, I just see a lot of talk about "true 35s" but most tires labeled 35x12.5... are only 34.5" in diameter. BFG/Cooper are obviously reputable too. I guess they want to label them something nice. Either way, 315/75r16 is pretty much a standard 35 to me. I have a buddy whose 37s actually measure just about 38". I'm sure this varies across manufacturers.
