4.0 engine in an 03 disco
Old Sep 25, 2018 | 12:01 PM
  #21
Nosugar0carbs's Avatar
I threw in a 2000 disco ecu bosch 4.0 into my 4.6 bosch, she starts for maybe a second or two nothing more. Seems to shut the fuel off as it does keep producing a spark if I keep spinning the engine over.
Old Sep 25, 2018 | 02:22 PM
  #22
2Guinness's Avatar
Donor motor will be here Friday. I am thinking of at least swapping out the heads with the 4.6 (SAI) ones I have that appear to be in very good condition. I am wondering if changing the Cam to the 4.6 one is in order?
Old Sep 25, 2018 | 04:19 PM
  #23
Charlie_V's Avatar
That's strange. I drove mine around with a 4.6 swapped in and didn't change anything electronic.
Old Sep 25, 2018 | 07:25 PM
  #24
Both vehicles run and drive, i did the immobilized trick to both cars before pulling anything, put the 4.0 ecu into the 4.6 donor car (only ecu), cranks and fires up for 1-2 seconds and nothing else until the key is cycled. Going to rebuild the 4.0 engine after I get this sorted out, my 4.6 at the moment has a noticeable tack from the lower end.... typical LR
Old Sep 27, 2018 | 09:23 PM
  #25
Charlie_V's Avatar
Hmm. I have never had to replace any electronics. But I have a complete extra set. Some years ago a forum member who owns a shop needed a set so I mailed them; he sent them back. I've always assumed they were a matched set and the BCU and ECU had to be swapped together.
I know my input on this thread is opposite of what you need to know because you are going the other direction than I went, presumably because the 4.0 is generally accepted to be more reliable. But I did not mess with the immobilizer or swap any electronics at all. And I swapped back to the 4.0. I think your original stuff is good (with the small exception of an ECU that expects ridiculous SAI components).
My original truck is non SAI. The 4.6 I rebuilt and destroyed was from an SAI truck. I just plugged the SAI holes with chopped and filled SAI lines....
you should be able to do the reverse of necessary...
bergin90
Dec 26, 2015 06:34 PM
5bravobravo
Oct 29, 2012 05:12 PM
jlipper
Oct 15, 2011 03:08 PM
striversrowatl
May 1, 2010 11:20 AM
Gordon Bombay
Jan 19, 2010 08:34 PM
