4.6 Discovery Cam & Lifters
Old Aug 23, 2014 | 02:18 PM
Alex_M's Avatar
Originally Posted by aroshan
if the lobes on your cam are worm out than it might be a good idea to replace it, (to check your cam all the way around leave the front cover on so you can turn the main pully to rotate the cam) if you do the engine needs to come out, unless the ac condenser is removed and even in that case i dont think there is enough clearance. if the cam is replaced than so should the cam bearings (D&D fabrication). to get to the cam timing cover needs to comes off and 2 bolts on the thrust plate, which is behind the cam sprocket which holds the timing chain. once you get this far it might be best to replace other stuff. my cam was worm out, and that wore out cam bearings and my thrust plate which also gave my timing chain some play so i replaced that also. the oil pump gears are a given it's like 25 bucks. if your just going to do the head gaskets than the lifters (tappets) are right there on top no need to pull the front cover. i thought the same thing about the ticking noise, turned out to be slipping sleeves. (notorious on the 4.6) here is are some pics to reference.
front cover off
here are your pushrods holding the tappets in place which be being all held in place be the heads and rockers.
sometimes the pushrods get stuck in the tappets slightly which will also need to be changed if stuck or bent. rovherfarm is a cheap source for these internal parts at a very decent price.
best of luck
You, my friend, are a god send. This is very helpful. Thank you.
Old Aug 23, 2014 | 10:17 PM
acamato's Avatar
You also need to remove the oil pan to remove the front cover. The oil pick up is bolted to the bottom of the front cover.
To remove the cam you need to remove the radiator. Some people have posted that they were able to move the condensor out of the way and remove the cam. I couldn't do that. I had to remove the condensor. Maybe thoes that we able to move the condensor didn't have ACE and rear AC like me.
ImQuattro
Jan 19, 2024 02:54 PM
ryanD2
Dec 23, 2012 10:08 AM
Thekid
Aug 1, 2012 01:43 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
