4.6 engine ?'s
Old Jan 21, 2014 | 10:15 PM
  #21
04duxlr's Avatar
Start with a heavier oil and then check the oil pressures. With these motors it seems that the first symptom of low oil pressure is ticking lifters and rockers, not a bearing knock from the bottom end. Seeing as how you have an '03, a cracked oil pump is a good possibility. That noise would come from the timing cover. If you aren't able to pinpoint the exact source you need to find a shop that can. The price for an installed oil pump isn't cheap but it's much cheaper than a new motor.
Posting a bid of the noise might not be a bad idea.
Old Jan 22, 2014 | 06:01 AM
  #22
drowssap's Avatar
change the oil and put a oil pressure gauge on it
Old Jan 22, 2014 | 08:30 PM
  #23
thegoat's Avatar
Thanks for the tips guys. I'll dump the oils and take it from there.
jlester@mt.gov
Mar 26, 2008 09:30 PM
christians1600
Mar 18, 2008 09:33 AM
Eulogio
Jan 21, 2008 04:17 PM
tcbinaflash
Jan 8, 2008 04:23 PM
miishmiish
Mar 8, 2006 12:31 AM
