Clicking?!
Old Dec 18, 2013 | 01:37 PM
srharney's Avatar
Default Clicking?!
I have a 2004 disco ii. For the last month or so i have been hearing a clicking noise when i accelerate. It sounds like it coming from the right side of the block when i am sitting in the drivers seat. I have alread replaced all the manifold gaskets so i know its not that. Any ideas as to what it could be?
Old Dec 18, 2013 | 02:08 PM
acamato's Avatar
Check your front driveshaft. They will click before they fail. When it fails, it will most likely take out your transmission housing also.
Old Dec 18, 2013 | 02:47 PM
srharney's Avatar
thanks i'll check it out
Old Dec 18, 2013 | 03:50 PM
jeffh's Avatar
I had a clicking once form that area under acceleration only... turned out to be a bad motor mount.
Old Dec 18, 2013 | 11:38 PM
mark d's Avatar
I have an 04 with ticking at idle. I think it is a bad/dirty lifter
Old Jan 21, 2014 | 04:59 AM
spikeRovah's Avatar
Were you ever able to rid of the ticking?
Old Jan 22, 2014 | 02:14 PM
mark d's Avatar
Don't know yet. I have towed my boat through central California in 108' heat with no problem. I know a few people have suggested I might have a slipped liner but I can't imagine I would not have coolant lose or other symptoms. I still think I have a sticky lifter
Old Jan 23, 2014 | 01:49 AM
Dane!'s Avatar
I'm OP's brother, its the purge valve, it wasn't coding, just sticking a little at idle.
EDIT: I had a completely clogged lifter that gave me a tick and a knock, I changed to 10W30 and put some Marvels Mystery Oil in there and it cleared it up and my engine runs great. I'm now running Royal Purple 15w40 though, I wouldn't recommend running 10W30 for extended use, I just used it to clear it out.
Dane.
domyo
Sep 25, 2008 12:19 PM
Lisa
Oct 17, 2005 10:00 PM
Lisa
Aug 20, 2005 11:16 AM
Lisa
Aug 8, 2005 10:31 PM
Yetielliott
Mar 14, 2005 05:15 PM
