4.6/hp24 into 4.0/hp22
I guess I will go ahead and end this thread since I just have a few little gremlins to chase down. I found a cracked manifold in my lower coolant lines. My oil sender is apparently a problem. And I may have a bad MAF or a coil issue. None of this impacts the swap though. It is just a matter of having sixteen year old parts next to new parts.
The bottom line is that the 4.6 works fine in a former 4.0 truck. Close off the SAI tubes if you didn't have them before and hook it up to your wiring harness and transmission. I have a spare zf4hp24 but I've decided to give my hp22 a chance. If you get a newer timing cover the oil sender may have a different thread than your old one. If you want to swap transmissions just be sure to get the swept transmission mounts because the bell housing in the bigger transmission pushes things back about an inch and a half to make room for a larger torque converter. Everything else is a drop in, direct fit. Assuming that I can chase down these gremlins I will be a happy camper indeed.
Thanks to everyone who has chimed in!! I have often said that the only reason I have kept this old Rover is that the people of Land Rover Forums are so helpful, and you are.
Best,
Charlie V
Best,
Charlie V
Double check that your pick up tube is tight and has the o ring or gasket. I forgot mine and had low oil pressure. If you have a pressurized lawn sprayer you can convert it to back pressurize the oil pump via the oil pipe. If you want instructions let me know.
Good luck though! I thought I just finished a full rebuild but it looks like I'm pulling the motor again... These things are finicky
I set a land speed record, fueled by adrenalin, pulling the pan, putting a new o ring on the pickup tube, replacing it, and returning the pan after dabbing some new rtv at critical locations... this with the pan always under the truck and off the ground.
At the moment I am idled waiting for a new plastic manifold for the lower coolant lines (ordered last night) so please do give me those instructions. I'd planned to just pull the fuel pump relay or the connection to the fuel pump and let the starter prime it for me. I also ordered new spark plug wires (Kingaborn 8mm RED) and I'm going to get some champion 318s today to replace my Bosch +4s.
Why do you have to pull it again? I hope it wasn't a bad injector causing a cascade of badness.
Video will be forthcoming for sure, but I have to wait for a few things: new plugs and wires and the coolant manifold. It is oiled up but has no coolant right now. I have an extra set of hoses but I would have to undo my bypass and I just don't wanna. The hoses I have are the old style without the manifold.
What manifold do you keep referring to?
For mine, either the rings didn't seat or the shop didn't check the bore correctly and because of that I have low compression. It still drives, but has lack of power and blowby. I'll get you instructions with pictures tonight or tomorrow when I'm out of class
I wimped out and used the 4.6 pistons. I don't know how much was taken off the heads and was guided by my bad luck in the decision.
This is what I am calling a manifold...
I just don't know what to call it. I have a third grade rover education and don't own a single spanner or propshaft--just wrenches and driveshafts and manifolds. The side out where the small heater hose is has a microscopic, invisible crack or hole. I watched it drip slowly, wiped it off, etc., moved the clamp, put a second clamp on it... I was actually real patient with it now that I reflect (#goldstarforme) all to not avail (#patiencegetsyounowhere). Because of where it sits and all of the inputs, clamps, and hoses it is hard to tell where coolant might be coming from. I finally lost patience, took it out and put soapy water on it, then used my hands to cover the holes and blew in the hose. The bubbles came out of the part right before the flange for that hose. I can't see anything wrong with it but I've spent too much money on my daughter's cats to let them drink my brand new antifreeze. I ordered a lower setup to get the plastic thing (manifold?) and have some new hoses to chop up for my bypass setup.
What you described on your engine is such a bad deal. Wow. I'm sorry to hear that. Sincere condolences. Alot of work to set that right.
