4.6/hp24 into 4.0/hp22
Old Aug 1, 2015 | 12:55 PM
  #151
abran's Avatar
Gotcha,
My point being is now you have an early D2 trans cooler and engine oil cooler. Whichever is bigger should end up being your engine oil cooler, or buy a 03/04 trans cooler and use as your engine oil cooler.
Old Aug 1, 2015 | 01:45 PM
  #152
Charlie_V's Avatar
Originally Posted by abran
Gotcha,
That latter is a great, great, GREAT idea. I assume they will fit the plastic slots. More cooling more better.
I used the larger transmission cooler but as you pointed out elsewhere the 03 stupidly does not have an oil cooler, so I just left the 00 oil cooler hooked up (since I haven't swapped the new engine in yet).
So, do you know for a fact whether the larger transmission cooler (if I buy one) will fit in the assembly as an oil cooler? That would be the bomb.
Old Aug 1, 2015 | 02:10 PM
  #153
abran's Avatar
For a fact.
https://landroverforums.com/forum/discovery-ii-18/2003-trans-cooler-sames-1999-2002-a-74833/page2/
Old Aug 1, 2015 | 02:30 PM
  #154
Charlie_V's Avatar
Awesome. More oil. Cooler temps. Fits. No downside. Imagonnamakethathappen.
Old Aug 8, 2015 | 10:43 AM
  #155
Charlie_V's Avatar
Camshaft arrived.
Old Aug 9, 2015 | 10:48 PM
  #156
Charlie_V's Avatar
While holding the camshaft for a trip to the shop Monday, my front driveshaft decided to die. Never ends.
Old Aug 18, 2015 | 07:58 PM
  #157
Charlie_V's Avatar
All bearings... cam, crank, rings... arrived. Ready to roll!
Old Aug 27, 2015 | 09:31 AM
  #158
Charlie_V's Avatar
So a little update.
Engine has dragged on a bit. I have another thread where I tried and failed to get a definite answer to the correct spec for a connecting rod housing bore, but I think/hope I got close enough. I had to order new conrod bolts (they are stretch bolts, fyi). Then I got bored and ordered some new wheel hubs. I also got a new CPS, MAF, and injector rebuild kit so I won't be chasing gremlins, and while I have been waiting I put a new fuel pump on. The cam is being fitted today. At some point I will be reassembling the engine... sooner the better. ATLDisco sent me his ABS Amigo so maybe I can banish the three amigos (at least, from everywhere except for my vacuum) before it is ready to install.
Old Aug 29, 2015 | 01:59 AM
  #159
Charlie_V's Avatar
[QUOTE=Charlie_V;523847]
Originally Posted by drowssap
the crank is turned UNDER-SIZED, so they bearing needed are OVER-SIZED.
the drive shaft will be 3/4 inch shorter on the 03.[/QU
Must be rear driveshaft... that's fine. I'll just use the driveshaft off the 03.
I installed a GBR double cardan driveshaft tonight. It has a longer spline and will work per Bill @ GBR. The old 03 driveshaft is now on a shelf.
Old Sep 2, 2015 | 02:16 PM
  #160
Charlie_V's Avatar
Okay! Engine is in the BACK of my rover so now I need to put it in the front.
