4 Low Question
Occasionally (rarely) I will put my D2 into 4L to keep the linkage from sticking. I've noticed that once I'm in 4L and take my foot off the accelerator there is a pretty noticeable lurch. Since I never actually use the 4L I'm not sure if this is normal behavior or indicative of some problem. Everything shifts smoothly in 4H.
Is this something to check out or not?
If that is the case, I would not worry about it. Sounds like the truck is behaving the correct way. I would be concerned if you are hearing some kind of grinding or popping sound. I have had the same experience with the CDL locked and in manual mode going down steep terrain. When I let off the accelerator, I was pushed forward in the seat because the truck's RPMs suddenly declined to match the gear that had been chosen.
edit: come to think of it, my '96 does the same thing when in Low.
