The 4H/4L stick moves
I did the CDL switch so my stick is mounted on top of the tranny. I just finished replacing all 4 motor/tranny/tcase mounts that were destroyed. Problem is that when I shift gears(D to R and R to D) the stick has some play to it, not much but it does move. Any thoughts? Is that normal? I would of never noticed if it was still a cable set up instead of the direct connection. Also there is a bit of vibration, should I be seeing that?
Thanks everyone.
Thanks everyone.
I just completed the CDL as well. Which method did you use? The D1 or the Ashcroft?
I did the D1 and discovered the same as you. It also would not let me completely put the shifter into unlock mode. I had to remove the top cover plate that has the small square hole to allow enough room for the shifter to completely unlock.
Yes, I have plenty of room, just my plate was restricting the full motion. Maybe i don't have it adjusted 100%. But when I had that plate on it took only mm to engage the cdl and I didn't like it. I think where I went wrong was that I had that plate off original when I installed it. So that would make the reason for the error.
