4hp24 question
Old 03-19-2023, 04:41 PM
acg's Avatar
acg
acg is offline
Check with Ashcroft UK and see if they can help:
https://ashcroft-transmissions.co.uk/product/zf4hp22eh/
Old 03-19-2023, 06:25 PM
Extinct's Avatar
Received 1,509 Likes on 1,069 Posts
Originally Posted by Jensen Vermont Stenberg
also, anyone have an idea what would I have caused this type of failure? I know I’m not the only guy with 200k plus on their rig. Could I have something going on in the transfer case? Misaligned bushing? Bad ring and pinion? This seems a rather uncommon issue apparently…this disco was a pavement princess when I got it from the PO, he had never used the diff lock or low range. I’m running 32” tires and do about 95% of my driving on the road, don’t really think it’s a driver issue. Could there be an issue in the t-case? Or just bad luck 😂
Wear is related to plates moving relative to the fingers. This unit has had a lot of shifting on it, it is the number of shifts. Not related to anything else. Which clutch/gear/drum is that?
Old 03-19-2023, 09:52 PM
Jensen Vermont Stenberg's Avatar
It’s the first gear pack, could make sense, the car was used in a lot of stop and go by the P.O. to commute to and from work in LA. Should I be concerned?
Old 03-20-2023, 01:37 AM
Extinct's Avatar
I would be concerned enough to put a different transmission in it.
Marco Jeroen Pieren
03-18-2020 02:17 PM
june82000
10-03-2015 06:57 PM
Disco28
05-29-2013 10:02 AM
tornado_735
01-31-2011 10:12 PM
ironstrike
01-10-2006 12:02 AM
Quick Reply: 4hp24 question
