4lo or 4hi won't come off dash
Hello everyone ! Newbie here just purchased a 03 disco 2, only thing is I can put it in 4 lo 4 hi works fine it also comes off and back to normal but the light on the dash stays on indicating they are still on any help would be awesome thanks in advance from Arizona
The Deputy (04-17-2020)
If the light is flashing and there's a chime sounding, under normal circumstances this would mean your transfer case is in neutral. If you have forward drive in Hi or Low then obviously this is not the case and your neutral switch is most likely stuck. Here's a link to a post showing the switch locations and functions. Since it is a normally open switch that passes ground when closed you should be able to unplug it and solve the immediate problem. Switch #1 is the one in question and its located on the top of the TC. The connectors are a bit of a bitch to get to.
https://landroverforums.com/forum/di...witches-97839/
Best4x4 (04-18-2020)
