4lo or 4hi won't come off dash
Old Apr 17, 2020 | 01:50 PM
Ivan0z's Avatar
Default 4lo or 4hi won't come off dash
Hello everyone ! Newbie here just purchased a 03 disco 2, only thing is I can put it in 4 lo 4 hi works fine it also comes off and back to normal but the light on the dash stays on indicating they are still on any help would be awesome thanks in advance from Arizona
Old Apr 17, 2020 | 02:09 PM
Richard Gallant's Avatar
Did you drive a few 100 meters, sometimes the light takes a minute to turn off
Old Apr 17, 2020 | 02:37 PM
Ivan0z's Avatar
Yes it's been on since yesterday I drove it a couple of miles just seems like the lights stuck and won't come off I can feel it come off and on when I engage the hi or lo maybe the switch ?
Old Apr 17, 2020 | 04:45 PM
Best4x4's Avatar
There isn't a light for 4Hi/N/4Lo position, however their are two related to the 4wd system. One indicates the gearbox is in N (orange with a gear image) while the other for CDL 94-99 D1 and 04 D2 (from the factory) will have an orange/red light for the CDL being enabled/disabled.
Old Apr 17, 2020 | 04:48 PM
Ivan0z's Avatar
Sorry not very familiar with the vehicle but it's the orange light !
Old Apr 17, 2020 | 09:29 PM
XRAD's Avatar
switch might need adjusting or connector cleaning. Probably has not been put into Hi/Low position change in years.....or it's not fully engaged..
Post a pic of light...
Old Apr 17, 2020 | 09:31 PM
Ivan0z's Avatar
Yea the lady never used them it beeps and won't stop beeping but I can feel it disengage and engage when I put it on thanks for the info ill.give her a shot tomorrow
Old Apr 18, 2020 | 08:53 AM
ahab's Avatar
If the light is flashing and there's a chime sounding, under normal circumstances this would mean your transfer case is in neutral. If you have forward drive in Hi or Low then obviously this is not the case and your neutral switch is most likely stuck. Here's a link to a post showing the switch locations and functions. Since it is a normally open switch that passes ground when closed you should be able to unplug it and solve the immediate problem. Switch #1 is the one in question and its located on the top of the TC. The connectors are a bit of a bitch to get to.
https://landroverforums.com/forum/di...witches-97839/
ljdiscovery
Dec 31, 2019 09:50 PM
GBR.R
Feb 19, 2017 05:27 PM
WarriorAce
Feb 11, 2014 09:40 PM
Bravhefen
Mar 5, 2012 05:35 PM
irish rover
Jun 30, 2007 10:15 PM
