4wd
on
there is a lockout solenoid in the transfercase that prevents you from shifting it unless you are in neutral. it can go bad, you can replace it or just remove it, but if you remove it remember not to shift it unless you are in neutral or you will be picking up peices of you drivetrain off the road.
i would say it would be something else however he just bought the truck. In most cases when its a new purchase most of these trucks have never seen dirt let alone low on the transfer case. More than likely on a new purchase it will just be ceased up from lack of use. If he was driving it and using it reguarly and then it wouldnt shift i would say different.
on
thats what my ex girfriend said.
Landys4ever
08-10-2009 01:06 PM
senorris08
01-08-2007 02:34 AM
