#8 misfire
Old Jan 27, 2016 | 01:57 PM
cappedup's Avatar
Originally Posted by jamieb
One day I may actually find out what SAI means and the thing actually does. I was guessing something like Secondary Air Intake. Other than that, it means, "bar someone put in my way just to be annoying". :-)
Ha. I'm going to take a stab. Without actually being sure.
I know it is secondary air injection. And it's an omissions lowering system. I think it re burns some gasses at startup to reduce the emissions during that time.
I could be very incorrect. I agree. It should mean "pipes in the way".
Edit dgi explains properly here. https://landroverforums.com/forum/discovery-ii-18/intermittent-sai-while-driving-77470/#post551510
Old Jan 27, 2016 | 04:02 PM
jamieb's Avatar
Can't believe I actually looked it up. According to the Range Rover people, you can disconnect it and the car will run fine, albeit with a CEL on.
Secondary Air Injection... can you ditch this?
Old Jan 27, 2016 | 06:01 PM
dgi 07's Avatar
Originally Posted by cappedup
Hey man, don't hold me to that..I'm just a grease monkey..
Old Jan 27, 2016 | 06:39 PM
jamieb's Avatar
http://m.harborfreight.com/inline-ig...not%20providedOk after a week of no codes the p0308 showed up today en route to harbor freight. Cleared the code, never came back. But I bought this ignition tester.
I checked plug wire for 8 and it was weaker, spiked brighter with each miss and erratic. Another plug was a strong, consistent spark light.
Definitely going to replace the wire and if that doesn't work going to check the coil. Hopefully not a head gasket leak, just had them done not long ago. Plus it has a rough idle still.
Old Feb 3, 2016 | 01:11 PM
BamaDisco2's Avatar
This. Just did the coils and a #6 wire myself. I really wanted to scream having to deal with that
Old Feb 3, 2016 | 01:18 PM
jamieb's Avatar
Now that I've already pulled the plenum twice, and pulled the MAF and IAC valve, I've gotten used to what's what. Saturday I am pulling the plenum and changing both coils and the wires. As long as I get the two plugs off the coils OK, I am no longer worried about pulling off the plenum. Even got a new gasket for it.
Bittersweet feeling. Happy to know I understand my truck better, but kind of annoyed I had to do the repairs at all. Live and learn, right?
Old Feb 6, 2016 | 05:04 PM
jamieb's Avatar
Resolved mine. I posted in the thread I started
BamaDisco2
Feb 4, 2016 09:27 PM
Gromeo
Jan 24, 2013 03:41 PM
Scott2747
Feb 8, 2006 12:11 AM
cottonpatchweims
Aug 15, 2005 11:19 PM
tbesselman
Jun 1, 2005 01:54 PM
