95-96 motor swap ?
Old Mar 15, 2008 | 09:51 AM
kraelo's Avatar
Default 95-96 motor swap ?
I have a 95 can I put in a motor out of a 96 ?
Old Mar 15, 2008 | 09:56 AM
kraelo's Avatar
Default RE: 95-96 motor swap ?
Can I use a motor out of a 94 Range Rover also ?
Old Mar 15, 2008 | 01:38 PM
okdiscoguy's Avatar
nope. you have a distributor, and the 96 has a coil pack. That was the year of the change.
THe RR has a different front cover than the disco. The short block might work if it is a 3.9 as well, but I am not positive.
Old Mar 15, 2008 | 01:46 PM
kraelo's Avatar
Yah the 94 RR has a 4.2 I believe ...
I found a 91 RR with what looks to be the same motor as mine ... 3.9 and offered to buy it from them,
we'll see if it works...
if you can please read up on my other thread and comment if you can, that one is the root of this question ..
Post- HeadGasket <--- name of thread..
thank you
Old Mar 16, 2008 | 05:09 PM
Landzu's Avatar
As long as the Range Rover motor has a distributor, Yes
The cam shaft on a 96 or newer motor has no drive gear
for the distributor.
bennyb43
Dec 11, 2013 08:17 AM
jacumja
Feb 14, 2011 06:08 PM
94svt50
Jan 24, 2011 03:46 PM
heartofrome@googlemail.com
May 25, 2010 12:32 AM
DuplinDisco
Apr 26, 2008 03:14 PM
