95 Discovery (green) - Misfiring
Old Aug 17, 2009 | 09:27 PM
mattrickman's Avatar
Thanks everyone..
Will do a compression test.
Spike - How would I check/test to find out if it is a vacuum advance issue?
thanks again
Old Aug 17, 2009 | 09:29 PM
First check you vacuum advance hose, look for cracks/split ends.
Hell, for $1 you can just replace it and rule it out all together.
If the hose is fine then I do not know how else to check it.
You can look it up in the RAVE manual.
Did you replace your cap and rotor when you did your plugs and wires?
Old Aug 26, 2009 | 04:45 PM
I am going to finally get around to working on this one, now that I got the cooling problem solved on my other discovery.
Will replace the vacuum line, like you said, Spike, it can't hurt.
I am also going to have the car repainted and see if that helps.
Disco Den
Dec 4, 2010 09:42 PM
gfeehan
Sep 1, 2008 09:41 AM
gfeehan
Aug 29, 2008 08:44 PM
maxellfullmoon
Mar 19, 2008 11:06 PM
mac1410
Oct 22, 2005 03:35 AM
