95 Water Pump
Old Jan 6, 2008 | 06:20 PM
skikatana's Avatar
7th Gear
Default 95 Water Pump
I've got Fluid pumping out of the front of what looks like a hole on the side of the water pump. You can see the hole right behind the belt of the pump? I pulled the Thermostat out and had to run it with out while the new one came in. The heat went out the other day and fluid is pouring out of the hole shown here and it is over heating again. Bad pump? Freeze plug hole? Help.
[IMG]local://upfiles/9074/3C86E85EAC5E400B9CC83FD06C507E75.jpg[/IMG]
[IMG]local://upfiles/9074/2EDA6834633F4489A84F571D04BC2BE2.jpg[/IMG]
Old Jan 6, 2008 | 06:25 PM
raid13's Avatar
Default RE: 95 Water Pump
if coolant is coming out of the vent hole then its bypassing
the internal seal inside the water pump, replace.
don't forget to use pipe tape on the three long 11MM headed bolts
Old Jan 6, 2008 | 06:41 PM
okdiscoguy's Avatar
X2, replace your pump, its bad. Make sure to keep you coolant topped off, that's why you lost heat.
I wouldn't drive until you replace it. These engines don't take overheating well....
Old Jan 6, 2008 | 06:43 PM
skikatana's Avatar
7th Gear
I tell ya what though.. This has been the toughest engine I've owned. I beat on this thing and handles it. Temps and all. Thanks for the info.. I'll start the replacement
Old Jan 6, 2008 | 06:45 PM
okdiscoguy's Avatar
You have been lucky. Aluminum heads and block with steel liners. Overheat and usually you drop a liner.....
Old Jan 6, 2008 | 07:02 PM
skikatana's Avatar
7th Gear
Do you know anything about the door handles on these things. I see from your Rover you have the same door handles as I do. I've torn the drivers side and drivers side rear door handles off. Easy to replace and where do you find them?
Ski
Old Jan 6, 2008 | 07:37 PM
okdiscoguy's Avatar
www.roverlandparts.com has good prices on good used stuff, but I would say E-bay right now...
http://cgi.ebay.com/ebaymotors/Land-...mZ190187510019
http://cgi.ebay.com/ebaymotors/Land-...mZ190187510805
I have bought form this seller before, and they are pretty good on shipping and getting you what was advertised.
Not too hard to get out.
Old Jan 6, 2008 | 08:02 PM
skikatana's Avatar
7th Gear
THANKS!!!!! You guys have been great.. Many thanks again..
A5scott
May 18, 2015 06:34 AM
discoboy
Dec 20, 2012 02:24 AM
Savannah Buzz
Jul 21, 2011 08:02 PM
Team140
Aug 30, 2009 09:41 AM
QUINCYSDISCOVERY3
Jun 8, 2008 06:50 PM
