'96 and '98 Disco I engine
Old Jan 25, 2009 | 03:17 PM
yellowlablounge's Avatar
Default '96 and '98 Disco I engine
My18 yr oldrecently damaged the hood, grille,bumper, lights, etc.on her 98 Disco I. I purchased a 96 Disco I for $800 that has a blown engine but good body parts. Just the body parts alone that I needed were $1,500 plus! The parts car hasn't arrived yet but I was thinking that the 96-99 Disco's all have the same engine and maybe the same transmission?Are all the engine, tranny, etc interchangable? I also found a '98 with a cracked head that supposedly that's the only thing wrong. If the '96 head is good, will it fit? Any estimate of the cost to do this?
Old Jan 25, 2009 | 04:21 PM
tomfraser's Avatar
Default RE: '96 and '98 Disco I engine
96-99 engines are the same, known as 4.0L
95 had different ignition system and is known as 3.9L
get a second answer though, because I am relatively new to rovers
Yes, the '98 is a drop in engine swap.
Exact same engine/trans/t-case/ECU/body/axles.....
Old Jan 25, 2009 | 06:28 PM
Thanks for the input.
Old Jan 25, 2009 | 06:33 PM
ORIGINAL: tomfraser
This is correct, pre 1996 Discoveries with the V8 used a distribitor, post 1996 V8 Discoveries use a electronic distibitorless ignition.
Spike555, thank you for the information. Hopefully I'll now have spare parts for a while. I'm no mechanic but I have been able to tinker with the '98 myself to fix a few things. The '02 Disco II Kalahari that my wife drives is a little more intiminating but it has a 100k warranty.
andytaylors
May 27, 2010 11:59 PM
Spencerfitch
May 9, 2010 04:44 PM
larsdisc1
Dec 17, 2009 07:06 PM
mellyagaunce
Sep 19, 2008 09:16 AM
tcbinaflash
Jan 8, 2008 04:23 PM
