96 Disco misfire P1316,0300,0303 codes
Old Jan 23, 2008 | 01:53 PM
FJL's Avatar
FJL
Default 96 Disco misfire P1316,0300,0303 codes
This has been an ongoing problem with my 96 Disco. I've changed the plugs, new Magnecor wires, Seafoam induction cleaning, Seafoam in the tank, changed the front O2 sensors (haven't replaced rear two yet). At Autozone they identified the following codes P1316, 0300, 0303. Car is still misfiring at 50 to 60 MPH range and failed emission test. I'm planning on adding a can of 44K to the gas tank. Any ideas as to what's next?
Old Jan 23, 2008 | 03:11 PM
Default RE: 96 Disco misfire P1316,0300,0303 codes
Pull a couple of plugs, including #3 and compare them for color and build up, then get back to me.
Old Jan 23, 2008 | 07:39 PM
bmwrovers's Avatar
I would try changing your fuel pressure regulator... i had the same problems, but after changing the regulator my disco is back to normal!
Old Jan 24, 2008 | 12:26 PM
FJL's Avatar
FJL
Don't even know what a fuel pressure regulator is. Can you tell where its located. Is this something I can DIY. Thanks.
moorebl
Aug 25, 2013 08:26 AM
jbarrios60
Jul 3, 2013 09:27 AM
csp
Jul 1, 2013 07:33 AM
black sheep
May 2, 2012 06:58 PM
mr_boondoggle
Freelander
Jan 21, 2009 05:08 PM
