97 d1 Ran hot on long grade
Old Sep 20, 2009 | 06:22 AM
discotruck's Avatar
4th Gear
Default 97 d1 Ran hot on long grade
I have been driving with no problems(sort of)until coming up a 5 mile mountain grade temp shot up.I was able to pull over,cool down,topped coolant checked fans,hoses and stuff.After,i restarted drove home for about an hour and no problems.Temp gauge always stays around halfway otherwise.What would you check?If the thermostat is wide open does the top hose always stay tight?
Old Sep 20, 2009 | 08:26 AM
The upper radiator hose will be hard as it is full of coolant, it will also be very hot so you can burn yourself.
I would look at the clutch fan, if it is not engaging then it wont move enough air to cool the engine when it is being worked.
The cooling system on a DI is very efficient and the clutch fan is only needed in extreme hot weather and when working the engine hard.
The electric fans are for the a/c and aux cooling only, they do NOT cool the engine under normal situations.
Old Sep 20, 2009 | 09:10 AM
Go have the coolant system pressure tested after you have verified that both the mechanical fan and both electronic fans work.
Old Sep 20, 2009 | 07:51 PM
petedisco96's Avatar
my overheating meant a new radiator and it was leaking. The radiator guy was not much help.
Francopacks
Aug 10, 2012 08:39 PM
MuddMouth
Oct 9, 2010 08:23 AM
mag48
Dec 17, 2009 11:13 PM
supremei
Aug 8, 2009 03:41 PM
tornado_735
Apr 24, 2009 07:33 PM
