'97 Disco drifting?
Old May 31, 2009 | 05:38 PM
  #31
AtlanticBritish has the bushing kits.
The kit includes every bushing on the truck and that is what you will need to do to fix it right.
If you replace just those bushings then you are only fixing part of the problem.
Tighten them until you can afford to replace them all.
Old May 31, 2009 | 05:56 PM
  #32
graham's Avatar
I'm chomping at the bit here....can't even download the friggin manual to see what I might look for. Is there any way to get those bushings only? I'd like to replace them all, but since that seems to be an immediate problem, and since I'm a NOOB, I'd like to start small I guess.
Old May 31, 2009 | 06:03 PM
  #33
I dont know if you can buy only those bushings or not.
Old May 31, 2009 | 06:18 PM
  #34
redhotbuzz's Avatar
Check these guys out ....http://www.dap-inc.com/parts/d1/d1_parts.shtml ...
Old Jun 2, 2009 | 08:10 AM
  #35
okdiscoguy's Avatar
May want to get the new end links for it too, while you are there. I forgot that DAP has such great prices on them. I replaced the front bushings, and then found a set of end links on e-bay really cheap. It improved the handling even more with the end links.
With almost every bushing and steering component replaced, it is tight as a drum. I let the dealer drive it and he was shocked. Then again, the paint leads you to believe it is a POS.
Old Jun 2, 2009 | 10:29 AM
  #36
graham's Avatar
Do you mean the end links for the sway bar?
Dirtnap
May 8, 2013 02:06 PM
ngarover
Oct 11, 2010 10:28 AM
