'97 Disco Key Fob Reprogramming
I disconnected my battery today on my '97 Discovery the key fob stopped working, how do i reprogram it? I searched old threads but they all say to look in the owners manual, I don't have one. Can anyone help me? Thanks
Andrew
Andrew
That didn't workthe remote won't lock it after i unlock it with the key, is there something i need to do to initate the relearn? should it disconnect the battery again?
OH no i disconnected the truck battery to clean a terminal in the fuse block not the remote battery The remote worked fine before I disconnected the truck battery. I thought i would just have to unlock the radio when i hooked the batt. back up but apparently i need to resync or program the remote.
Do the lock sequence using the key in the door. I started to look last night, but didn't get back on.
Also, have you replaced the battery in your fob? I thought I read somewhere that if your lights didn't flash while locking or unlocking, you may have a battery going bad in the fob.
I'll see if I can search later if that doesn't work.
ORIGINAL: Offroadss350
