'97 Disco Key Fob Reprogramming
Old Feb 25, 2008 | 03:04 PM
Offroadss350's Avatar
Default '97 Disco Key Fob Reprogramming
I disconnected my battery today on my '97 Discovery the key fob stopped working, how do i reprogram it? I searched old threads but they all say to look in the owners manual, I don't have one. Can anyone help me? Thanks
Andrew
Old Feb 25, 2008 | 07:42 PM
Default RE: '97 Disco Key Fob Reprogramming
The key does not need to be reprogrammed. There is not a computer chip in the '97 key.
Or are you talking about the keyless remote?
Old Feb 25, 2008 | 08:16 PM
yes, sorry i thought the keyless remote was also a key fob. But yes the remote is what needs to be programmed. Thanks,
Andrew
Old Feb 25, 2008 | 08:25 PM
Unlock the trk with the key and then lock it with the keyfob at least four times.
Old Feb 25, 2008 | 08:40 PM
That didn't workthe remote won't lock it after i unlock it with the key, is there something i need to do to initate the relearn? should it disconnect the battery again?
Old Feb 25, 2008 | 09:28 PM
Are you sure the battery is in right? Is the remote bad and not the battery?
Old Feb 25, 2008 | 10:08 PM
OH no i disconnected the truck battery to clean a terminal in the fuse block not the remote battery The remote worked fine before I disconnected the truck battery. I thought i would just have to unlock the radio when i hooked the batt. back up but apparently i need to resync or program the remote.
Old Feb 26, 2008 | 07:22 AM
okdiscoguy's Avatar
Do the lock sequence using the key in the door. I started to look last night, but didn't get back on.
Also, have you replaced the battery in your fob? I thought I read somewhere that if your lights didn't flash while locking or unlocking, you may have a battery going bad in the fob.
I'll see if I can search later if that doesn't work.
Old Feb 26, 2008 | 05:07 PM
ORIGINAL: Offroadss350
I have disconnected my battery more than once and I have not had to reprogram my remote.
Old Feb 26, 2008 | 07:23 PM
Thanks guys it was just a low batt. in the remote.
ruffram
Jul 9, 2020 10:38 AM
Discolife
Nov 25, 2011 11:38 AM
pilsner
Apr 7, 2008 03:24 PM
HollandandHolland120
Oct 18, 2007 06:24 PM
Jay
Apr 27, 2005 03:49 PM
