97 Key Fob Programming
Hey there,
I did a quick search and could not find an answer.
I have a 97 SD Disco (my third) and a two button key fob remote, I dont have the owners manual so cant look up the procedure. Google only leads me to the single button procedure.
Any help would be appreciated.
Thanks,
Oscar
Thanks,
Oscar
With a two button remote you will need to take it to the dealer. If you have two you should take them both because they have to be programmed at the same time. The instructions you found found won't work on the later models.
For anyone looking forthe instructions for a one button key fob, here they are...
HANDSET INITIALISATION
NOTE: New handsets are supplied in pairs.
If a new handset is required, it will require
initialisation to the ECU using the
following procedure:
1. Starting conditions: ignition off, doors unlocked,
bonnet switch depressed.
2. Carry out instructions 3. to 9. within 8 seconds.
3. Switch ignition ON.
4. Switch ignition OFF.
5. Lock doors.
6. Unlock doors.
7. Release bonnet switch.
8. Switch ignition ON.
9. Switch ignition OFF.
If alarm is correctly accessed, horn will sound and
LED will light. It is now possible to programme two
handsets of correct frequency to vehicle alarm ECU.
This must be carried out within two minutes.
10. Press and hold down button on first handset until
dash LED flashes.
11. Repeat instruction 10. for second handset.
12. The LED will extinguish if both handsets have
been initialised correctly.
5. Lock doors.
6. Unlock doors.
dash LED flashes.
HollandandHolland120
10-18-2007 06:49 PM
