97 Key Fob Programming
Old Mar 10, 2007 | 09:52 PM
Ahhsk's Avatar
5th Gear
Default 97 Key Fob Programming
Hey there,
I did a quick search and could not find an answer.
I have a 97 SD Disco (my third) and a two button key fob remote, I dont have the owners manual so cant look up the procedure. Google only leads me to the single button procedure.
Any help would be appreciated.
Thanks,
Oscar
Old Mar 11, 2007 | 04:11 PM
Ahhsk's Avatar
5th Gear
Default RE: 97 Key Fob Programming
Will the one button procedure work if I just use the lock button on the two button remote?
Thanks
Old Mar 11, 2007 | 11:43 PM
billinohio's Avatar
i use a site called www.discoweb.com
Old Mar 12, 2007 | 02:40 AM
Ahhsk's Avatar
5th Gear
Ok is that a joke because I typed Disco? Is that a no no around here?
Old Mar 12, 2007 | 03:27 AM
97DISCOIDAHO's Avatar
With a two button remote you will need to take it to the dealer. If you have two you should take them both because they have to be programmed at the same time. The instructions you found found won't work on the later models.
For anyone looking forthe instructions for a one button key fob, here they are...
HANDSET INITIALISATION
NOTE: New handsets are supplied in pairs.
If a new handset is required, it will require
initialisation to the ECU using the
following procedure:
1.
Starting conditions: ignition off, doors unlocked,
bonnet switch depressed.
2.
Carry out instructions 3. to 9. within 8 seconds.
3.
Switch ignition ON.
4.
Switch ignition OFF.
5.
Lock doors.
6.
Unlock doors.
7.
Release bonnet switch.
8.
Switch ignition ON.
9.
If alarm is correctly accessed, horn will sound and
LED will light. It is now possible to programme two
handsets of correct frequency to vehicle alarm ECU.
This must be carried out within two minutes.
10.
Press and hold down button on first handset until
dash LED flashes.
11.
Repeat instruction 10. for second handset.
12.
The LED will extinguish if both handsets have
been initialised correctly.
rwatkins3678
Jan 7, 2019 12:32 AM
BD_LR4
Apr 29, 2010 11:57 PM
Timpala`
Feb 4, 2009 07:01 PM
smartsigntools
Jan 8, 2009 08:21 PM
HollandandHolland120
Oct 18, 2007 06:49 PM
