98 Disco Issue, I'm at a loss
Old Aug 16, 2009 | 04:39 PM
BDevilDog's Avatar
3rd Gear
Default 98 Disco Issue, I'm at a loss
Ok here is the situation, 98 Disco with 170k miles on it. Started idling high so I cleaned the throttle body and Air Intake, Cleaned the MAF put it all together and it helped a little. Now it threw the code for misfire see Manuf. which by reading on other posts the answer is to change plugs and wires which I did. Unfortunately it is WORSE!!! it sputters, stays running as long as in park but once in gear drops down on the rpms and dies. I need help.
Old Aug 16, 2009 | 04:52 PM
lipadj46's Avatar
What is the actual codes you are getting? Are you sure you got the wires on correct?
Old Aug 18, 2009 | 02:37 PM
BDevilDog's Avatar
3rd Gear
Default ok ok I'm an idiot
Ok so the supposedly pre gapped plugs, weren't and the numbering order on which side was even and which side was odd for putting the wires back on was backward. Anyway, got it done running fine now just idling high and I ordered an new air intake valve as that is hopefully the only problem. This weekend......fuel filter and engine cleaning, should be fun.
Thanks for the help.
Walter
Old Aug 18, 2009 | 06:14 PM
Never assume that the spark plugs are gapped correctly.
The same spark plugs that fit your engine also fit countless others and they may have a different plug gap than you.
Old Aug 28, 2009 | 09:12 AM
BDevilDog's Avatar
3rd Gear
Default Idling still a problem
Ok so I got the new air intake valve in and changed it, cleaned the MAF and still Idling high. Not going up and down just idling high about 2500 then about 1200 when in gear. Any help would be appreciated.
Old Aug 28, 2009 | 10:10 AM
AK Rover's Avatar
You've got a vacuum leak somewhere. Trace all your vacuum lines and check them for cracks. And quit cleaning your MAF before you kill it and cause more problems. The MAFs on these trucks are pretty sensitive and don't take cleaning well.
Old Aug 28, 2009 | 01:52 PM
camaroz1985's Avatar
I had the same problem and like AK stated I found a vacuum hose that was off.
Old Aug 28, 2009 | 03:17 PM
lst1187's Avatar
Default Just went through a similar situation....
Vacuum hoses first....they are easy/cheap to replace. Mine were original and needed it. The one from the right side rocker cover to the ram housing gets a nice little crack in it that is common. My particular issue was the Throttle Position Sensor (TPS) broke. Inside there are 2 triangle shaped 'stoppers'. One side broke. When this happened, the vehicle tried to compensate which led to High RPMs. Once I repaired the broken piece (with superglue) there was too much glue residue and the TPS seated a bit off which led to Higher RPMs. This put the voltage reading at twice the approriate amount and the vehicle assumed I had my foot on the throttle and did not compensate. I shaved the TPS down until the voltage read properly and the vehicle compensated. All that being said, I have a great friend at a Land Rover Centre and he hooked up to the testbook so I could read the voltages as we repaired the TPS. The TPS is easy to take off and see what I explained. Good luck.
Old Aug 31, 2009 | 09:31 AM
Mine seemed like it was fixed with vacuum hoses, but then it started idling really low (400rpm). I'm going to try to clean the throttle body, and the IAC, and see if that works.
cipher982
Feb 27, 2013 08:59 AM
wiltone
Aug 12, 2011 11:40 AM
Rover Red
Nov 16, 2010 08:41 PM
tunernewb92
Oct 20, 2009 07:15 PM
ontheroadagain
Mar 27, 2008 08:10 PM
