99 boosted with leads reversed - no crank now
Old Jan 21, 2015 | 02:10 PM
98xc800's Avatar
Default 99 boosted with leads reversed - no crank now
Tow truck operator boosted my 99 DII with the polarity reversed. I put a new battery in, but it won't crank over now. I have flashing S and M trans lights.
Any ideas?
Old Jan 21, 2015 | 02:36 PM
dusty1's Avatar
you can burn electronics, pop fuses, burn alternator. sounds like you could have immobilized yo ride (is your led on, as you try to start). m&s could be because you were -9v.
Old Jan 21, 2015 | 02:45 PM
DustyLBottoms's Avatar
Yeah, he'll need to go 24v now to overcome the -9v deficit.
Old Jan 21, 2015 | 03:21 PM
dusty1's Avatar
okay....under or less than
Old Jan 21, 2015 | 04:10 PM
98xc800's Avatar
The immobilized led is not on. The park light on the shift bezel is not on, so maybe that has something to do with it.
Old Jan 22, 2015 | 03:40 PM
dgi 07's Avatar
Sounds like you should start checking fuses. You got one fuse box under the dash and one under the hood. S
Old Jan 22, 2015 | 04:25 PM
FantomRover's Avatar
Had a buddy do this once, it was a d1. Check your under hood fuses. I believe the fuse that he blew was the 100 amp alternator fuse
twoxred
Oct 4, 2021 07:07 AM
innzane
Jul 12, 2012 10:08 PM
tcbinaflash
Nov 20, 2011 10:47 AM
Savannah Buzz
Jun 16, 2011 09:20 PM
treant985
Jan 9, 2011 03:49 PM
