99 Disco 2 intermittent start problems
Old May 9, 2013 | 09:18 AM
Phant0m's Avatar
I'll take it down to the shop to have then give me the results, voltage, etc. sadly I have no clue what to say I need done exactly since I'm no mechanic.
I'll check out eBay as mentioned for a used fuel pump.
What's been happening the last few days is the engine light will turn on then the "M" and "S" starts blinking. The drive "D" blinks as well. When this happens it feels like it gained a ton and drags when I step on the gas.
Once I turn off and turn on the Disco it starts back up and runs as if nothing happened.
Old May 9, 2013 | 09:24 AM
Phant0m's Avatar
One more thing, how do I test the fuel pressure? Really don't trust this local mechanic.
Old May 9, 2013 | 09:39 AM
Before you go to the shop, send me your number and I'll walk you thru what needs to be done.
Also, never install a used pump, all you are doing is swapping your old pump for another one that could be worse, assuming you actually need one.
Old May 10, 2013 | 06:08 AM
drowssap's Avatar
for test purposes you can use a tire gauge to test fuel pressure, it wont be exact but it will tell you if you have pressure. There is a shrader valve in the rear of the engine by the coils
Old May 10, 2013 | 06:55 PM
Phant0m's Avatar
Hi Mike, I sent you a PM!
Thanks for the info drowssap
Old May 17, 2013 | 11:51 AM
Phant0m's Avatar
An Update,
Not sure if its the cam shaft sensor, I know it states sensor.
Now that she is not running, But the Disco does still crank like it wants to start. I was able to retrieve the codes. Here is a list of what the diagnostics machine produced:
P1590 - Rough road signal, impulsive drive cycle, A: signal impulsive
P0340 - Camshaft position sensor, A: circuit (Bank 1 or single sensor)
P0560 - System Voltage
P1536 - Air Conditioning Compressor, power stage fault drive cycle, A: Signal Missing.
Thanks
Old May 17, 2013 | 04:42 PM
Phant0m's Avatar
Mike, I been trying to reach your phone but I don't want to trouble you by constantly calling.
Disco, now wont start at all and when when ignition is in position 2 the windows wont roll down.
Also a weird thing the other day, When I got it to run temporarily, when I attempted to lock the doors as I was driving, instead of locking the doors, the horn would honk.
I have been reading throughout the forums and don't want to conclude it's the cam shaft position sensor, don't think it would be responsible for the other weird events with the disco.
Where do I check the voltage? and If Disco needs to be running to check the voltage them I'm assuming I can't?
Thanks
Old May 20, 2013 | 12:58 AM
Phant0m's Avatar
Don't mean the post a million message just updating in case anyone else is also having the same problems.
Thanks for the convo DiscoMike.
After we spoke I took the battery out to autozone and had it tested and it was 12.5v with a load.
I popped the battery back in and extra tightened the connectors and it started right up, prior to doing nothing. I will invest in new battery connector cables and see if I run into any more problems.
Thank you.
JamesDisco97
Dec 2, 2013 06:36 PM
Roverfix97
Mar 26, 2010 04:41 AM
jonman
Aug 14, 2008 10:50 AM
DiscoGal
Oct 17, 2006 03:36 PM
baysiderover
Oct 6, 2006 06:58 PM
