99 Disco II - 60 K Service / Fog Lights / Tires
Old Aug 22, 2005 | 02:52 PM
mikemeyer0's Avatar
Default RE: 99 Disco II - 60 K Service / Fog Lights / Tires
ORIGINAL: Charlie L
Hey Mike
OK, already bought the Hellas on Autoeverything.com.
For the tires, I went to tirerack.com and put in 265/65/18 which sounds like what I want. However, nothing came up....Any other tire stores online where I can do some research on this?
Alsolutely pumped to get going!
Thanks
CL
here are pretty much the tire sizes avail. for you at a tire store.
235/65-18 - 1" taller in diameter, but a bit narrower
275/55-18 - .9" taller in diameter, and a little wider
285/55-18 - 1.3" taller in diameter and a bit more wider than the 275/55's
I would go with the 285/55-18's if I were you, with a agressive All-Terrain.
Old Aug 22, 2005 | 07:36 PM
Charlie L's Avatar
Hey Mike
Outstanding. I like the idea of the 285/55/18. I presume there would not be a noticeable difference in gas mileage. Also I presume that there is no safety concern going to the higher profile. The wider profeil should offset that concern I guess.
Bottom line is I want this beast to look sharp too.
Thanks alot once again
CL
Snowdog
Apr 7, 2016 01:05 PM
Frank4
Nov 21, 2015 05:47 PM
abran
Oct 1, 2013 09:09 PM
jordamf
Aug 2, 2011 09:04 AM
pvenuti
Oct 13, 2010 03:48 PM
