99 Disco II engine replacement
Old Nov 9, 2008 | 10:05 AM
mechanic's Avatar
Default 99 Disco II engine replacement
Which year engines can I put in my disco? Will the 4.6 mount up and what computer settings are required?
Thanks...chris.
Old Nov 9, 2008 | 10:49 AM
Disco2Guy's Avatar
Default RE: 99 Disco II engine replacement
Not sure about the computer settings, but you can use any D2 engine (99-04). I would avoid an 03 engine since they have the oil pump issues. If you use an '03 check that the VIN is out of the TSB range.
Old Nov 9, 2008 | 11:50 AM
If you get the 4.6 you will also need the 4.6 ECU. You can get your ECU reprogrammed, but it might be cheaper to buy the 4.6 ECU, used of course.
For a drop in replacement get a 4.0 from a DII.
www.roverlandparts.com
bennyb43
Nov 28, 2015 04:01 PM
jasran01
Jan 11, 2011 05:23 PM
North Shore Rover
May 25, 2010 11:01 PM
tunernewb92
Jan 22, 2010 03:43 PM
