99 DISCO2 FUEL PROB
Old Dec 6, 2004 | 01:54 PM
kartoudi's Avatar
Default 99 DISCO2 FUEL PROB
Hey there,
Does anyone know what is the best solution to this problem I have. My friend and I ran a test on my vehicle. The code came up with this:
"Running to rich on bank #2" The code number was 1175.
Someone told me that it means that Bank 2, which is one side of the engine block, is burning too much fuel, which could mean there is not enough air? Can anyone explain and give me the right avenue of what I should do?
Thanks,
George
Old Dec 6, 2004 | 04:31 PM
Lighting90's Avatar
Default RE: 99 DISCO2 FUEL PROB
Will have to find out about these dratted codes, as I can see one day I will own a Landie with a black box fitted..
Old Dec 11, 2004 | 04:47 AM
jury22's Avatar
Hi George I assume you are running a V8, if the fuelling is too rich on one bank suggest that the lambda sensor which is in the exhaust just down stream from the engine manifold may not be working properly. If you look at the following site it tells you how to test these components basically you need to see the voltage changing, once the engine is hot. The other way would be to swop the sensors on the 2 banks and see if the code changes to the Bank 1
http://www.ntksensors.co.uk/
Since code is so specific then must be this or a faulty injector perhaps
Good Luck and let us know how you get on
Newbie1989
Jan 17, 2011 07:32 PM
alan kenyon
May 17, 2006 06:16 AM
disco12
Jan 28, 2006 10:47 AM
cowgirl1989
Jan 10, 2006 04:53 PM
Ash A
Nov 15, 2005 01:38 AM
