99 Discovery 2 melted O2 plugs
Old Nov 22, 2016 | 11:33 PM
jjjsudderth's Avatar
4th Gear
Default 99 Discovery 2 melted O2 plugs
Thank you in advance! I could not find an answer usig search. Both upstream O2 sensors have plugs that are melted together. How do I replace them? Do I simply cut them off and splice new plugs in? If so, where do I get said plugs? Will the splice effect the readings given?
Thank you again so very much for any constructive responses. I rely on this forum more than you know.
Old Nov 23, 2016 | 06:40 AM
JUKE179r's Avatar
Do your connectors look like the below picture?
If so, you can cut out the connector and splice the wires together if you have enough slack in the wire assembly.
IMO... I'd go another route to try and find another suitable QD connector or buy a new O2 sensor assembly and reroute the wire assembly(or add a heat resistant sleeve) so it won't touch the exhaust.
mossmanxjt
Aug 7, 2019 11:09 PM
southen96disco
Dec 7, 2012 09:49 PM
Travelor
Aug 7, 2011 04:43 PM
jycsalas
Jul 25, 2010 05:40 AM
jycsalas
Oct 21, 2008 11:49 AM
