99 Discovery. Heater trouble.
Old Feb 16, 2007 | 03:10 PM
aholmes100's Avatar
Default 99 Discovery. Heater trouble.
I am have a 99 Discovery II. Recenly have developed some trouble with heating. Even when the car is warmed up it blows cold air when I am stopped.Once I start moving and keep moving it starts blowinghot air. Then again if I stop at a light it goes back to blowing cold air. Once I start moving and pick up speed it goes back to blowing hot air.
Kind of strange. Can someone help.
Thanks
Andrew.
Old Feb 16, 2007 | 03:14 PM
Default RE: 99 Discovery. Heater trouble.
Andrew,
Your truck is running very low on coolant. I would suggest you top off the coolant bottle and have some do a pressure test on the coolant system to find the leak. You want to rull out head gaskets as soon as possible. If you are lucky, it may only be some external coolant leak.
Make sure you only use Dexcool coolant in your engine.
Mike
Old Feb 16, 2007 | 03:21 PM
geoman's Avatar
Also open up the hood and look for evidence of a coolant leak on the drivers side valve cover (orange color staining)--towards the back of the cover. This will indicate the throttle body heater plate is leaking, and must be corrected NOW. When you start it in the morning, does the inside of the windshield fog up at all?
regards,
Geoman
Old Feb 22, 2008 | 09:01 AM
wbstyles's Avatar
I have the same thing happening to me. No, the windshield does not fog up. I replaced the heater plate gasket, and thought I fixed the problem, but continued to smell coolant. I noticed that I was getting some indications that it was leaking by the small amount of coolant on the floor. It seems to be coming from the front passenger corner of the vehicle. Any ideas?
Old Feb 23, 2008 | 09:58 AM
okdiscoguy's Avatar
find where the coolant is leaking from. You say it is leaking inside the truck?
ls1morethanyou
Jan 12, 2017 10:21 AM
sterlingclassicautoparts
Feb 6, 2014 12:03 AM
Matt_Attack352
Jan 13, 2014 09:55 AM
LCollins1990
Feb 3, 2009 05:43 PM
Rosembelt
Feb 5, 2008 05:47 PM
