99 Discovery Overheating
Old May 19, 2010 | 04:13 PM
Justwannaride's Avatar
Default 99 Discovery Overheating
Before anyone gets annoyed I have read through similar topics concerning my problem. I just want to be sure that I'm understanding correctly. Don't bite my head off please!
My Discovery was running fine until I ran my air conditioner one day. Now it is overheating. When I ran the air conditioner I noticed the coolant was leaking out so I turned it off. I suppose it all ran out and the next day my car overheated while driving. I added more coolant and it was fine for about 20 mins before it ran hot again.
I noticed when I put coolant in, it pumps out of the top and spills over. I'm not very saavy when it comes to repairing cars so I will be taking it to a mechanic, I just want to be semi knowledgeable so that no one will take me for all that I own just to fix this (if it's nothing major). Based on what I've read I'm thinking it's either the thermostat or the water pump.
Am I correct?
Old May 19, 2010 | 05:50 PM
audiS4S6's Avatar
Am I correct?
If you're lucky. Very lucky.
If you have to drive it, crank the heat so it helps the engine stay cool. You can deal with it to save your engine, right?
Old May 19, 2010 | 06:06 PM
greg409's Avatar
Ditto, "coolant was leaking out so I shut it off, overheating, it all ran out, I drove it the next day, it overheated again, I added fluid" ---those are all very scary subjective terms.
At best, needs some cooling system service, at worst there's no end...
You don't say if it's a DI or a DII, the coolant should be replaced every 30k miles according to LR.
let us know how it goes, please
luck,greg
jayfinn3
Jun 19, 2008 10:46 AM
wadematt
Jun 12, 2008 09:30 AM
bigun
May 14, 2008 08:49 AM
patrickh98039
Apr 8, 2008 07:09 AM
04DiscoverySE
Jul 18, 2006 08:02 AM
