99 Discovery Steering Pump Replacement
On the DI, power steering pump is a easy replacement part. Haven't some folks used a GM power steering pump as a cheaper replacement. When removing the pump from the housing, there are two bolts inside the housing that's not easily seen. After removing all the other bolts, you will wonder "why isn't this pump coming out" It's because of those two bolts. Once the two bolts are removed, it will slip right out like butter.
I think it was for simplicity, the ACE system on a DII requires power steering fluid so they just made the power steering system on a DII to use the same type of fluid as the ACE system would be my non educated guess.
