99 Discovery Steering Pump Replacement
Old Jun 14, 2009 | 05:37 PM
whammond's Avatar
3rd Gear
Default 99 Discovery Steering Pump Replacement
I have a 99 Discovery with a steering pump that is going. It is leaking from the pump and make a horrible noise when I turn the steering wheel. Is this a really big job. Does anyone have a step by step on how to do this?
Thanks,
Louie
Old Jun 14, 2009 | 05:41 PM
DI or DII?
Old Jun 14, 2009 | 06:19 PM
Either way, no it is not a major deal other then the cost, don't buy any reman's from local auto parts stores, they tend to fail alot.
Check out Atlantic British and Rover Connection for both new and their good reman's.
Make sure to use the right fluid when flushing out the system.
Old Jun 15, 2009 | 12:28 AM
CandiMan's Avatar
On the DI, power steering pump is a easy replacement part. Haven't some folks used a GM power steering pump as a cheaper replacement. When removing the pump from the housing, there are two bolts inside the housing that's not easily seen. After removing all the other bolts, you will wonder "why isn't this pump coming out" It's because of those two bolts. Once the two bolts are removed, it will slip right out like butter.
Old Jun 15, 2009 | 07:44 AM
whammond's Avatar
3rd Gear
Its a Discovery II
Old Jun 15, 2009 | 07:46 AM
whammond's Avatar
3rd Gear
And whats the "right" fluid?
Old Jun 15, 2009 | 08:41 AM
D1's use ATF, D2's use P/S fluid.
Old Jun 15, 2009 | 08:50 AM
CandiMan's Avatar
What's the difference between the two systems that causes them to use different types of fluid?
Old Jun 15, 2009 | 09:53 AM
Nobody knows, nobody knows.
I think it was for simplicity, the ACE system on a DII requires power steering fluid so they just made the power steering system on a DII to use the same type of fluid as the ACE system would be my non educated guess.
bustedwheel
Oct 18, 2019 04:21 PM
logic2
Aug 31, 2013 08:38 PM
0304Disco
Mar 26, 2012 03:48 PM
bustedwheel
Mar 14, 2012 06:49 AM
hhalimi
Jan 24, 2012 09:24 AM
