99 Drive Shaft, Valve Cover, Exhaust, and Oil Pan Questions...
Old Feb 22, 2011 | 10:52 AM
logicmike44's Avatar
Default 99 Drive Shaft, Valve Cover, Exhaust, and Oil Pan Questions...
Making preperations for Spring repairs, and have a few questions...
Wondering if the pics show update or original drive connectors?
Valve Cover screws are tight, do i need to replace VC gasket?
Oil Pan look like sealant was used, and not gasket...???
Is their a bolt missing, or does the exhaust look normal ?
Attached Thumbnails 99 Drive Shaft, Valve Cover, Exhaust, and Oil Pan Questions...-imag0014.jpg   99 Drive Shaft, Valve Cover, Exhaust, and Oil Pan Questions...-imag0015.jpg   99 Drive Shaft, Valve Cover, Exhaust, and Oil Pan Questions...-imag0027.jpg   99 Drive Shaft, Valve Cover, Exhaust, and Oil Pan Questions...-imag0021.jpg   99 Drive Shaft, Valve Cover, Exhaust, and Oil Pan Questions...-imag0019.jpg
Old Feb 22, 2011 | 11:01 AM
Bundu's Avatar
Banned
Those are new u joints in your drive shaft. Give them grease until you see fresh grease coming out at each cap.
You are missing a nut and stud from your exhaust, there should be 3.
If tightening the VC bolts did not help then you need new VC gaskets. Consider replacing your spark plug wires at the same time, because the VC gasket job will require you to remove the upper intake and that will make the plug wires easier to replace.
Degrease your engine, it is hard to tell from all the grunge there. It is easier to determine where the leak is when the engine is clean.
Bahamarover
Aug 6, 2014 11:34 PM
oilspotLR
Oct 7, 2012 08:50 PM
rlrigsby
Feb 12, 2010 08:53 AM
lipadj46
Nov 17, 2009 11:13 AM
