99 II - Power Steering Pump or PS Box?
Old Apr 5, 2010 | 11:45 AM
bennycisco's Avatar
Default 99 II - Power Steering Pump or PS Box?
Dont' know if pump or box.
Drove to final destination with no problems, parked car overnight outside. Temperature dropped to 5 degrees overnight, and 15 in morning. I went to turn the ignition over, and a loud whining erupted and subsided. When I tried to turn the steering it was difficult and made a loud moan-whining sound. There were no leaks. I drove the car home with no turning issues, but the sound persisted. When I arrived home, the hose had sprung a leak and fluid flowed out. Replaced the hose and fluid - no leaks, but the moaning-whining sound continues at start-up and when turn steering wheel.
Pump or box?
Old Jan 20, 2013 | 08:48 AM
rcg'sdisco's Avatar
I have the same issue. What did you do to solve this?
Old Jan 20, 2013 | 09:05 AM
When was the last time you flushed your p/s system?
Burned oil can cause the sound by damaging the pump.
Have you checked the belts condition and tension?
Old Jan 21, 2013 | 07:40 AM
rcg'sdisco's Avatar
I got into it and found a leak in the low pressure line from the pump to the reservoir. It's leaking right at the pump. I cut back the hose and stopped the leak. But found that it is still leaks over time. Looks like I will be replacing the line. I believe it's drawing in air when running causing the reservoir to foam and the pump to moan. p/s the fluid is brown and needs to be flushed.
johnkbl
Sep 21, 2023 06:17 AM
joshjellel
Feb 16, 2015 10:53 AM
Joseph M. Broomhead
Feb 4, 2013 03:14 PM
DiscoBritney
Dec 19, 2011 06:24 PM
losinov
Mar 21, 2011 08:57 PM
