AB radiator hose PITA
I just replaced the lower hose and t-stat on my DII. I paid extra for a hose from atlantic british to make sure it was a good fit. The factory hose is all rubber the AB hose is made up of 3 different hoses with a hard plastic joint..well guess what..hard plastic doesn't flex. A metal oil line was in the way, after trying for an hour I had to bend the oil line about 1/4" just to get the hose on. Hopefully the oil line will not leak. anybody else run into this problem?
I just went through that 2 weeks ago, except I replace all of the hoses and not just the t-stat and lower hose.
I also ran into the same problem, but I disconnected the oil line instead of bending it. It was more work but I was worried about busting it and having to wait another 4 days to receive the part. The lower engine hose from AB is actually an original Land Rover part. They just changed them because the original all rubber ones were more prone to failure just like the original upper radiator hose. When they changed the design on the lower engine hose they apparently never thought or cared about the person that would have to install it. Typical of automobile manufactures.
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
![Mad](https://landroverforums.com/forum/images/smilies/MMiQGA5.png)
water pump went out back during the summer..went I put a new one on I accidentally tore one end of the hose..took it off and cut 1/2" off hose..put it back on..seem to work find until now..started leaking
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
Did you use a space saver clamp or a regular screw type clamp for the hose that goes into the water pump.
i used a regular screw type clamp but thats not what messed up the hose...I messed it up with a screw driver trying to pry it off the water pump..it was really stuck on there good
FYI...If your not 100% certain of their age, clean them off and take a close look...the manufacture date is stamped on them somewhere. After my truck over heated (due to a bad water pump and HG), I did all my hoses last summer. I later found that the old hoses were stamped with a 2008 Mfr date. They probably didn't need replaced, but the truck was new to me, had no service history, and had problems, so I decided it was better to be safe than sorry. I've put them away to save as spares...
D2 2003
11-07-2017 07:41 AM
