ABS 4086 question
Old 12-17-2014, 12:31 PM
trialrun's Avatar
Default ABS 4086 question
I did a search and didn't find any definitive answers, so i'll pose this to the group.
The 3 amigos popped on w/ the brake light. Plugged up the Hawkeye and pulled: 4086: Front Left Sensor Intermittent sensor out put during driving, broken wire. Cleared the DTC and drove for a day, then it popped back on, same code. ABS line is plugged in no visbile breaks
My question - do I have to replace the entire front left hub assembly or can I just replace the ABS sensor? (I noted that roverparts sells both, 400 bucks vs 160
Thanks
Old 12-17-2014, 01:04 PM
dusty1's Avatar
well you could just do the sensor, but then you are faced with "what if its the hub or wire?".
I have spare used units for such things. I can swap it out and see on the cheap.
do you have the plug set up or the full length wire from sensor? scenario... I stretched a rear wire and got the same type code for rear. I could not see a visible damaged area. swapped hub and in with a new sensor......same code. I then decided it was wire related. so I cut the sensor wires further back (up to a convenient spot at frame) and spliced in new wires. I have since spliced in extended wires at all 4 corners. I just use direct burial low voltage wire from hd or lowes, I butt splice, then shrink wrap. cheap and easy, if you want to try that first.
trialrun (12-17-2014)
Old 12-17-2014, 02:12 PM
trialrun's Avatar
Dusty - thanks for the insight, i'll see if Paul has any extra hubs I can test it with (hoping it's just the wires, they were stretched by the prior owner).
Is that the same low voltage wires used for yard lighting? I thnk I have some left over from last summer
Also I noted a slight pulsing sound coming from the ABS module in the engine bay right after I turned the vehicle off
Old 12-17-2014, 03:08 PM
dusty1's Avatar
that works, but might have to get some cut at the spools, in electrical (so you aren't buying 250'). I just got the as close to same gauge uv/direct burial as possible (I think stranded 16/2....maybe 14) do not even remember its intent, it was a roll on the sprinkler system parts isle over by plumbing. guessing it is used as legs to the valve solenoid in the sprinkler system.
this....
colemtd
03-30-2019 08:57 PM
dammad
01-26-2009 01:50 PM
cottonpatchweims
02-10-2005 07:18 PM
cottonpatchweims
01-14-2005 01:59 AM
Quick Reply: ABS 4086 question
