ABS Codes....
Old Feb 24, 2009 | 06:21 PM
brooksa's Avatar
Default ABS Codes....
I had my ABS codes read today by a indy mechanic who was nice enough to do it for free and got these codes;
"Right Front Wheel Sensor"
"Shuttle Valve Switch"
He cleared the codes and advised me to start with the wheel sensor first, what do you guys think? ABS/TC is not working by the way.
thanks
Old Feb 24, 2009 | 07:40 PM
As long as the brake pads and rotors all look good then yes, start with the wheel sensor.
Old Feb 24, 2009 | 08:03 PM
brooksa's Avatar
Rotors and pads are good,
After replacing the sensor (and that is indeed the problem) will the ABS begin working?
thanks Spike
Old Feb 25, 2009 | 08:18 AM
If your ABS is not pulsating, you will need to rebuild the module with the new $800 kit.So let me make sure I am understanding you correctly, if you attempt a panic stop on a loose surface, you don't feel the pulsation thru the brake pedal?
buick56
May 15, 2013 06:11 PM
04SSHD
Apr 11, 2012 06:20 PM
yuenie
Jan 13, 2010 05:37 PM
BajaXJ92
Dec 3, 2009 07:43 PM
cottonpatchweims
Jan 14, 2005 01:59 AM
