First Rover - Question on Alignments
Old Feb 22, 2009 | 07:45 PM
Yeats5.0's Avatar
Default First Rover - Question on Alignments
I just bought my first Rover. I noticed that the left front wheel has alot of negative camber probly 1.5 degree. I know thats too much! It drives funny too. Is there a common problem that would cause that? The wheel bearing is tight and the ball joints don't have any movement. I'm thinking the spindle must be bent. I doesn't have anything obvious that would support that, but being a straight axle it would almost have to be. Right?
Old Feb 22, 2009 | 08:03 PM
You have non serviceable hubs on both front and rear axles.
I do not know if a bad hub would cause that or not.
Just take it to a alingment shop and have it checked out.
Here is a new hub.
http://www.roverparts.com/Parts/TAY100060.cfm
Old Feb 24, 2009 | 11:46 PM
sharp's Avatar
Regarding the steering wheel and alignment. Put on 4 new tires and just had my alignment done. Car runs straight, but the steering wheel is not centered. Is this OK? I just bought the Rover and not sure how long it was like this.
Old Feb 25, 2009 | 09:35 AM
Yeats,
Find a good alignment shop that works on 4X4's and have then look, this is not common.
Sharp,
The shop that did your alignment should have centered your steering wheel as part of the alignment, take it back.
EL GALLO
May 1, 2010 12:40 PM
tornado_735
Mar 28, 2009 05:34 PM
Heybuck59
Mar 7, 2009 05:02 PM
sloppyjoe
Nov 5, 2008 05:24 PM
Skibum232
Nov 20, 2007 05:46 PM
