abs...codes...and rumbling noise + ticking noise
Old 05-26-2012, 05:40 PM
30more's Avatar
Default abs...codes...and rumbling noise + ticking noise
i got a p1509 and p0455, the p1509 comes with a rumbling noise coming from the abs pump and the p0455 comes with a loud ticking noise exhaust leak?
help once a again!
Joe
Old 05-27-2012, 08:18 AM
Go are missing on both, the 455 is a gross evap leak, sometimes the gas cap but usually something else.
The 1509 is you idle solenoid clicking, may be failing, may need cleaning.
Shout if you have any questions.
Old 05-28-2012, 04:29 PM
30more's Avatar
how do you clean it, with what? i guess i wont worry too much about the 455.. what do you think? thanks
Old 05-28-2012, 05:01 PM
wilson96rr's Avatar
remove it and clean it with carb cleaner.
SCIGONE
LR2
11-26-2018 12:09 PM
Humdinger
10-18-2016 05:05 PM
john65b
10-10-2013 05:00 PM
ewok
03-16-2011 10:16 AM
Quick Reply: abs...codes...and rumbling noise + ticking noise
